Grouting question
1 Apr 2006
When wall tiles butt up to floors, door frames and ceilings is it o.k. to grout those joints or should they be finished with a flexible frame sealant or similar product? Cheers
??????? It's fine to use grout????? or it should be frame sealant??????
hello flemsbog
always leave an expansion joint filled with flex sealant
hope this helps ;)
Use grout at all joints apart from when you're talking about a wet room or an area where you're having a shower. No need for silicone unless it's got water running on it.
I always use flex on them joints an Im a Pro guy ........Council Building Control say the same .....btw its nothing to do with a wet area its EXPANSION joint for movement , All corners/ floors an ceilings flex 5mm building control
hope this helps :)
