DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fitted a bath but water pressure is low
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dynamicd
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 9:55 am    Post Subject:
Reply with quote Thanks
hi just fitted a new bath but the water pressure seems a lot lower than the old one the bath i fitted has taps in the centre and i had to use a couple of 90 degree bends would this cause it
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sat Aug 05, 2006 10:40 am    Post Subject:
New taps prob. have smaller holes inside .......very common now as they are all from China icon_mad.gif
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Sat Aug 05, 2006 10:43 am    Post Subject:
nige is right, fancy pants ceramic dish taps designed for high pressure direct system, installed on a low pressure gravity system will never work
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
micky p
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 06, 2006 7:57 am    Post Subject:
have you used flexable pipes as well or connected to copper/ plastic. Its just the amount of times ive seen people use these flexable pipes and they are necked.
Back to top
 Alert Moderators
sp
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 07, 2006 10:18 am    Post Subject:
or
you may have low pressure taps
is your taps water flow like a garden tap or spray type ?
if it is spray type, it may have restrictor at water out point
just undo nut at water outlet points, remove restrictor and refit the nut
this might solve your problem
Back to top
 Alert Moderators
dynamicd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 15, 2006 2:56 pm    Post Subject:
thanks everybody looks **** i'll just have to live with it
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitted new bath taps, and the water flow is very poor 9 940 Fri Aug 06, 2004 10:47 am
Fitted bath taps 3 2140 Tue Jan 24, 2006 12:41 pm
New combi fitted, query bath tap temp 3 420 Fri Jan 11, 2008 7:16 pm
Fitted new bath 3 3660 Tue Jul 10, 2007 10:25 am
new bath fitted 2 460 Sun Jun 17, 2007 12:46 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
