DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
adding sockets
This topic originated from the How to page called Extending a ring circuit using existing sockets
Click here to return to the page called Extending a ring circuit using existing sockets.
  View previous topic :: View next topic
Author Message
skara68
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 07, 2006 8:39 am    Post Subject:
adding sockets
Reply with quote Thanks
I want to add 3 sockets to my garage supply which is just a spur (Double socket) How to? Legally!
skara68
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 07, 2006 10:48 am    Post Subject:
As always, it depends...
You need to verify that your earthing and bonding are up to snuff and that the extra load will not be an issue.
You will need to inspect and test the existing circuit and verify that it is suitable for the addition you propose.
If the existing socket is just a spur you will almost certainly need to install a fused spur unit.
You will need to ensure that these sockets are RCD-protected - you can incorporate one into your fused spur if the circuit does not already have RCD protection.
If your garage is detached from the house you will need to notify building control or employ a registered electrician.
Back to top
 Alert Moderators
salem2000
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 08, 2006 7:22 am    Post Subject:
I was under the impression that a detached garage was not in a special location/installation, and as long as the work does not include outside work you do not need to notify Building control. If all your going to do is extend the circuit, then I don't see a problem. I believe it mentions this on page 8 of the Approved Document. (Link below)
Part P Here (This is a Pdf file)
Salem.
__________________
1010011010
Back to top
 Alert Moderators
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 08, 2006 6:06 pm    Post Subject:
Yes, you're right, beg pardon. I was forgetting this is just an extended circuit. However all the other stuff applies, regardless of P.
Back to top
 Alert Moderators
salem2000
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 08, 2006 8:02 pm    Post Subject:
__________________
1010011010
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
What cable for adding sockets please?? 21 660 Thu Feb 08, 2007 9:56 pm
Adding sockets to a ring main 3 560 Mon Jan 08, 2007 3:11 pm
adding extra sockets 4 780 Thu Apr 14, 2005 11:31 pm
adding sockets to a ring 6 5000 Sat May 28, 2005 3:06 pm
Adding sockets to outbuilding and loft 4 180 Wed May 20, 2009 1:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
