bowtan
Joined: 08 Aug 2006 Posts: 2 Location: Essex, United Kingdom Thanked: 0 times
Posted: Tue Aug 08, 2006 11:00 am Post Subject: SOCKETS |
I recently changed my kitchen sockets from plastic to stainless steel lookalike, but I keep getting a shock from 2 of the sockets the rest in the kitchen are fine. |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Tue Aug 08, 2006 11:45 am Post Subject: |
What sort of a shock?
Static spark when you touch one, and then nothing, or a tingling?
Have you checked for trapped wires?
Is there a proper earth connection on the sockets?
Do you think that maybe you should call an electrician, given that you have created a possibly lethal problem that you don't know how to investigate or solve? __________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth. |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Tue Aug 08, 2006 11:54 am Post Subject: |
Incidentally, if you get a bit of a shock when you touch it with warm dry hands, when you are wearing shoes and socks, then you can expect to get a much worse one if you have wet hands, are not wearing shoes, or are touching some other piece of metal (such as the sink, or a kettle, cooker or toaster) with your other hand.
If you have children in the house they are particularly likely not to wear shoes, and I would be very anxious about the risk of shock. |
bowtan
Posted: Tue Aug 08, 2006 1:30 pm Post Subject: |
Problem solved ! A socket under the worktops that I had fitted, the plate fixing screws were touching the back of a shallow box I have now re-fitted with a deeper box and all is well. Thankyou for your suggestions. |
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Tue Aug 08, 2006 1:39 pm Post Subject: |
it sounds like there is something badly wrong, relying on plate screws is just about tollerated for earthing the backbox but i certainly wouldn't rely on it for earth continuity to a socket.
is there any earth wire going to the earth terminal on the socket? |
ban-all-sheds
Steve
Joined: 15 Apr 2005 Posts: 12856 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Tue Aug 08, 2006 4:42 pm Post Subject: |
reckon he'll be back? |
