DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fused sockets
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
jeff43lincs
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 08, 2006 8:15 pm    Post Subject:
fused sockets
Reply with quote Thanks
hi
i have a unused (for 15yrs) fused socket in my kitchen which was used for turning my immersion heater on upstairs,would it be ok to take this socket out and replace it with a double plug socket
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 08, 2006 8:42 pm    Post Subject:
if you mean a switch spur, well yes if outgoing cable has been removed. you will need to check what size cable is feeding it if it is 2.5mm cable it can go on a 20A breaker maximum. you will also need for it to be protected by an RCD if it could be used to feed outside of your property
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Aug 09, 2006 10:13 am    Post Subject:
Yes
Maybe.
It could be a spur from a socket circuit, in which case it can simply be replaced by a socket, subject to the normal rules for unfused spurs.
Yes.
And Jeff - if you are in Lincs then the law says that you have to notify your LABC before you do this.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fused spurs used for sockets & lights. 3 280 Thu Jul 10, 2008 9:00 pm
adding sockets to a fused spur 2 860 Fri Sep 28, 2007 9:04 pm
Can i run two double sockets off a fused spur? 14 1300 Sun Jan 07, 2007 7:57 pm
Can i add more than sockets from a fused spur? 3 600 Thu Mar 13, 2008 11:18 am
Fused spur and 2 double sockets after??????? 2 800 Mon Mar 07, 2005 6:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
