Hi
We have had the shower for about 3 or 4 years now and for the last 12 months the flow of water has reduced to a mere trickle (the hot water that is, the cold is fine). I'm not sure if it is just the shower that's got a limescale build up or something to do with the pipe work.
The hot water tank and boiler is down in the cellar and has to travel upwards. We also have a cold water tank up in the loft which is where the cold water comes from, so the hot water is forced upwards? But when the shower was first installed the hot water was fine coming up from the cellar so we're not too sure what the problem is. If anyone could help I would very much appreciate it, because Im desperate for a decent shower. Also would fitting a pump be adviseable to improve the pressure, if so how hard are they to fit yourself?
Cheers
Rod
Cheers
Rod
