JanetWright
Joined: 11 Aug 2006 Posts: 2 Location: Yorkshire, United Kingdom Thanked: 0 times
Scrit
Joined: 21 Dec 2005 Posts: 1094 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Fri Aug 11, 2006 5:10 pm Post Subject: |
Hello and welcome
Scrit __________________ Measure twice, cut once - except fingers!
Thermo
Joined: 21 Oct 2004 Posts: 8452 Location: Sussex, United Kingdom Thanked: 31 times
Posted: Fri Aug 11, 2006 9:06 pm Post Subject: |
how big a gate is it? __________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference |
JanetWright
Scrit
Posted: Sat Aug 12, 2006 12:57 pm Post Subject: |
Surely you are probably going to need to buy posts with the lugs already cast-in, or go ti steel posts with ligs welded on.
Scrit __________________ Measure twice, cut once - except fingers! |
Thermo
Posted: Sat Aug 12, 2006 3:26 pm Post Subject: |
im guessing theyre for a driveway then. It all depends on the weight of them really. You can drill through concrete posts and bolt the lugs through. Youll need to do it carfully with an sds drill and do it from both sides to aviod break out. __________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference |
