DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cable size to consumer unit
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
Jimbomakavechi
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 3:18 pm    Post Subject:
Reply with quote Thanks
Hi all,
I live in council rented accomodation and the mains cable that feeds the consumer unit seems to be a single core earth cable that is about 6mm to the outer plastic covering. This seems too small to carry all of the mains power. Do you think that this is correct, or could it be dangerous?
Thanks,
Jim
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 3:41 pm    Post Subject:
I'm not sure why you're asking, is the cable getting hot?
Back to top
 Alert Moderators
Jimbomakavechi
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 3:47 pm    Post Subject:
I am asking because typically the councils tradesman do poor quality work and take shortcuts. I am about to buy the flat and once I do any defects are my responsibility, therefore insurance etc could be voided if incorrect or non standard wiring is in place. I would rather get this sorted now if there is a problem rather than have a nasty surprise later.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Fri Aug 11, 2006 4:08 pm    Post Subject:
Post a picture of the CU area (upload it to some webspace and give use the link) and we will take a look
you should also note that very very few houses are exactly to BS7671, and a large percentage have quite big/lots of defeats, even newbuilds believe it or not (contracts awarded to lowest bidder... who then use cheap unskilled labour, etc) so I wouldn't get too wrapped up in the insurance thing unless your house is a deathtrap electrically wise.
You could have a PIR done if you are worried about your wiring, this can be done by a electrician, however they may not all offer this service
Back to top
 Alert Moderators
Jimbomakavechi
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 11, 2006 4:13 pm    Post Subject:
OK will do, thanks. I will also put some appliances on and see if there is any heat actually emanating from the mains feed cable.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Aug 11, 2006 5:29 pm    Post Subject:
Re: Cable size to consumer unit
Jimbomakavechi wrote:
Hi all,
How does that work, then?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Fri Aug 11, 2006 7:08 pm    Post Subject:
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Aug 11, 2006 10:08 pm    Post Subject:
If it's TT, 6mm2 suffices...
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Fri Aug 11, 2006 10:11 pm    Post Subject:
Even if its not... 6mm˛ just scrapes through on the adiabatic IIRC(assuming that the Ze is low enough to clear the service fuse in 5s or less and if its not, you have bigger issues...)
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Aug 12, 2006 8:05 am    Post Subject:
... 6mm to the outer plastic covering. ...
I don't know what that means, but I don't think it means 6mm˛
Back to top
 Alert Moderators
Gaz the Sparky
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 12, 2006 8:33 am    Post Subject:
Council Electrics
I work for a local city council rewiring and maintaing council houses and the wiring is certainly isnt a bodge. There seems to be this misconception that council workers are ruff and bodge jobs well they dont. My council even go to the lengths of installing 10mm t&e for a cooker circuits (to future proof) where as new builds use 6mm t&e
Right rant over but it does wind me up when people say thay council workers are ruff because I CERTAINLY AM NOT!!!!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Aug 12, 2006 8:41 am    Post Subject:
I'd second that, councils tend to think in terms of total cost of ownership so are willing to specify a quality that won't need frequent maintenance and upgrade.
Will buy on specification first and price second.
Back to top
 Alert Moderators
Gaz the Sparky
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 12, 2006 9:14 am    Post Subject:
Cheers John D nice to know not everyone feels the same way about council workmanship
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sat Aug 12, 2006 6:10 pm    Post Subject:
And as for the standard of workmanship, I have worked in countless council wired houses, and it is incredibly rare to find a bad one. I also used to work with a few ex-council sparks, and they was never any bodging or corner cutting going on.
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Sat Aug 12, 2006 6:29 pm    Post Subject:
Have to agree that most council properties are to a high standard.
I test many council houses and find that the standard of work and accessaries used are high quality. Periodic inspection is carried out at change of tenancy so most properties are of a standard that complies to the current wiring regulations and they have to funding/ money to do it the right way and not cut corners.
I know a few people that work for the local council and they are very knowledgable because they get to take up many courses such as ONC/HNC that other companies just would not be able to justify.
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
[b]Cable size and type between the meter and consumer unit[/ 3 720 Tue Dec 23, 2003 8:22 pm
Size of amp in consumer unit 7 420 Tue Mar 06, 2007 2:43 pm
Consumer meter tail length and size?. 6 1200 Fri Jun 29, 2007 8:33 pm
New cooker cable size 2 5240 Sat Dec 16, 2006 11:19 am
CABLE SIZE 4 3100 Sat Dec 02, 2006 5:06 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
