neloids
Joined: 11 Aug 2006 Posts: 1 Location: Hampshire, United Kingdom Thanked: 0 times
Posted: Fri Aug 11, 2006 6:31 pm Post Subject: upgrading radiator. |
Hi,i want to change a radiator from a single to a double panel as my living room tends to be a bit chilly.problem is the pipes to the radiator valves come through the wall.so what i wanted to know is do plumbers,as a rule,leave enough pipe inside the wall to pull a bit through because the new valves will be about 25mm further away from the wall,or should i just leave well alone and put a jumper on instead. |
chrishutt
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Fri Aug 11, 2006 6:54 pm Post Subject: |
The only way to find out is to disconnect the valves from the rad (watch out for loads of dirty water) and try pulling them forward. If it's a partition (plasterboard) wall then there's a good chance that they will be loose. __________________ Let's face FAQs. |
