DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower Pressure Mira Sport
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
Author Message
George38
from United Kingdom
PostPosted: Sat Aug 12, 2006 1:42 pm Reply with quote
I have 2 Mira Sport 9.0kw electric showers. One in bathroom & one in ensuite. The thermostat needs to be turned up by 4-5 clicks warmer in the ensuite shower for the same temp but pressure drops of significantly to the point where it is useless. Both room temps equal.
Why should there be such a difference?
Any ideas welcome ?
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 2:10 pm Reply with quote
is it the case that you can turn the dial behind with the cover off i have had this on other makes. some showers tell you to turn the internal dial with the cover off fully one way then turn knob on front all that way also. then when you put the front on this allows for the hottest shower. if the keyway only goes on one way this is not the problem.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 2:14 pm Reply with quote
i've got a mira sport dont want to take off the cover have you got a booklet on it i will go look for mine
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 211 times
PostPosted: Sat Aug 12, 2006 4:37 pm Reply with quote
i think what fireman22 means is the front dial may be "out of line" with the actual switch it controls inside. Take the cover off and turn both the switch inside and the front dial the same way, until they stop, then refit the cover. See if this works.
Both showers are on mains water, aren't they?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 738 times
PostPosted: Sat Aug 12, 2006 6:42 pm Reply with quote
It sounds like one of the elements has failed in the ensuite shower.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
mira sport shower 8.5kw, low pressure light 13 160 Sun Sep 04, 2011 2:12 pm
Mira Sport Max Shower 4 120 Tue Aug 14, 2012 12:54 pm
Mira Sport Max 10.8kW Shower Installation 6 280 Thu Apr 21, 2011 2:23 pm
Mira Sport electric shower no power. 5 2620 Tue Feb 26, 2008 12:02 pm
mira sport shower burnout 2 720 Thu Feb 21, 2008 12:12 pm
DIYnot
