DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Help! Can\\\'t decide on anything!
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
northcoombes
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 12, 2006 2:18 pm    Post Subject:
Reply with quote Thanks
We\\\'ve had our bathroom redone and are now doing the last things. We want to put in recessed spotlights with one above the shower. The room is small - 2.3 metres X 2.6 metres. How many ceiling lights would be suitable?
We also need to put in a fan but when we try and research it on the net we get totally confused - how strong a fan do we need? Should we vent it through the roof or the wall?
Any help much appreciated!
Mimi
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 12, 2006 2:22 pm    Post Subject:
you can get an inline fan with a light and fan point in one to go ovr the shower. soffet board venting is easy-est of all otherwise 4" hole through cavity wall or lead tile in roof, roofer job really
i would say 4 light in ceiling
Back to top
 Alert Moderators
Job_n_knock
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 13, 2006 5:43 am    Post Subject:
You should have had the electrics done first. You have presumably done the tiling etc so I would suggest that either you do as Fireman says and vent it via the space above or, fit a 4" extractor fan at high level so you can discretely feed it from above. You do however need to feed it via a 3 pole fan isolator. This is purely so the fan can be isolated independantly from the circuit it's on because they usually have a run on timer. The isolator is usually fitted above the bathroom door so again if you make it high level you can discretely feed it from above. As to your confusion, its its a smallish room which bathroom generally are then a 4" should be enough, the next size up is 6" but the same wiring applies.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Aug 13, 2006 5:50 pm    Post Subject:
And please note, should you care, that this work is notifiable.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
northcoombes
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 22, 2006 10:38 am    Post Subject:
Thanks for this info guys - really appreciate the input.
mimi-nc
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Aug 22, 2006 10:49 am    Post Subject:
Try to avoid making a hole in the roof as you are asking for a leak. Ceiling and soffit are fine, or you can hire a core drill and put a 105mm duct in the wall which is very neat.
If you put lamps or fans above the bath or shower they will have to be low-voltage (so it is less trouble not to).
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
