DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing Single Ceiling Light with Spots
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
Goto page 1, 2  Next
Author Message
martb
from United Kingdom
PostPosted: Sat Aug 12, 2006 3:37 pm Reply with quote
Hi All,
I have recently had a small extension built onto the back of the kitchen and had the electrics done by a qualified electrician. The electrician put a light switch into the new room and a single ceiling light. The Mrs has now decided we are having spotlights in the new room to match the kitchen so I need to get a bit of advice before I attempt the job!!
I removed the existing light cover and found the following wiring in place...
http://www.promantraining.com/images/existing_wiring.gif
Can you please advice how I should wire the new spotlights into this circuit. The spots are 50w halogen with block connections for Live and Neutral only. The instructions tell me not to wire an earth as they are double insulated!?
Any advice or even a wiring diagram would be very much appreciated.
My email address if anyone wants to send a diagram is martin@urbaninteractive.co.uk
Thanks in advance
Mart
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 3:43 pm Reply with quote
yes mart, you should wrap some brown tape around right hand blue cable in first pic as this is the live return from the switch. you can use a few choc boxes to joint the cales but basically wire a two core cable from junction you make at exisiting light then just daisy chain around from light to light you will end up with one cable in last light. so at first light you connect your new two core cable blue to the blue and brown to the blue with the brown tape switched live from switch
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 3:47 pm Reply with quote
obviously at the first light you will have four connector blocks in your choc box, blue with blue of new two core cable, two earths together, two browns together and blue with brown tape with brown of new two core cable
Back to top
 Alert Moderators
martb
from United Kingdom
PostPosted: Sat Aug 12, 2006 3:48 pm Reply with quote
Cheers for the fast reply,
Just for my own peace of mind, all I need to do is basically replace the existing light with the first spot and then daisy chain on from this? Will the very last spot need to return to the first to make a loop or not??
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 3:52 pm Reply with quote
yes exactly, no, no need to return, one cable in last spot
Back to top
 Alert Moderators
martb
from United Kingdom
PostPosted: Sat Aug 12, 2006 4:02 pm Reply with quote
I'm beeing a bit stupid here so forgive me but why only one cable in the last spot?
Will it be brown or blue in the last spot?
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 10 times
PostPosted: Sat Aug 12, 2006 4:31 pm Reply with quote
sorry mart went away, one two core cable i mean. all spots two core cable in two core cable out. you know two blue together two brown together with cable from spot in with these also. if spots have blue and brown coming out there will be three blue and brown at each spot
Back to top
 Alert Moderators
martb
from United Kingdom
PostPosted: Sat Aug 12, 2006 5:25 pm Reply with quote
Got you now, thanks for your help.
I will post tomorrow to let you know how it went. If I don't post you know it went very wrong!!!
Back to top
 Alert Moderators
laughingjester
from United Kingdom
PostPosted: Sun Mar 15, 2009 7:28 pm Reply with quote
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sun Mar 15, 2009 8:26 pm Reply with quote
gravedigger...
why post in a 3 year old post???
Back to top
 Alert Moderators
laughingjester
from United Kingdom
PostPosted: Sun Mar 15, 2009 8:46 pm Reply with quote
why not? what harm is it doing you? and havent you just done the same thing:lol:
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sun Mar 15, 2009 8:53 pm Reply with quote
no, I replied to a post that the last post was dated today..
it's not like you evenhad anything usefull to add, just a jestfull comment..
Back to top
 Alert Moderators
laughingjester
from United Kingdom
PostPosted: Sun Mar 15, 2009 9:05 pm Reply with quote
are you ok ? is there something you would like to get off your chest? are you having problems at home ? icon_cry.gif
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sun Mar 15, 2009 9:17 pm Reply with quote
I just spent 15 mins reading through a long dead post and even replied to it before i realised that it was 3 years old and hadn't been resurected for a good reason...
we don't do this for fun and wasting time on long dead posts gets on my "small bird family whos members include Great and blue"..
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Sun Mar 15, 2009 9:21 pm Reply with quote
He asked a civil question asking why you replied to a post which was 3 years old. It was a rational and intelligent question.
Please do him, and all the other readers of this forum, the courtesy of a civil explanation for your behaviour. It would be beneficial for you if it were a rational and intelligent explanation.
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
3 spots replacing a single light, do i need spurs? 16 10740 Sat Jan 01, 2005 10:23 pm
Replacing ceiling light with 5 recessed spots 14 1780 Wed Nov 16, 2005 12:44 pm
Replacing an existing ceiling rose with spots 5 1100 Thu Jul 19, 2007 10:56 pm
Ceiling rose & pendant to tracker and spots 5 3320 Fri Nov 21, 2003 5:47 pm
ceiling spots 2 440 Mon Feb 27, 2006 10:08 pm
DIYnot
