condenser or vented?
5 Jun 2006
Leeds
I am looking to purchase a tumble dryer.
It will be located in the kitchen with an external wall directly behind. Creating a hole for a vented machine wont be too much of a problem.
I was after opinions as to which to buy.
I know that a condenser machine used more electricity per cycle but I assume it also heats the room. With a vented machine all the heat goes directly outside.
Is there anything else to consider?
Thanks in advance
Never ever ever ever buy a condensor dryer if you can fit a Conventionally vented one they take twice as long to dry and are less economical to run. If you can get a hose through the wall use the conventional.
Edd
