Following on from a previous post, I would be grateful if someone could answer a question.
I have a Potterton Profile 80e running 12 rads and the problem is that when the hot water cylinder switches on the temp in the rads drops off to almost cold. At the same time the boiler starts to \\\'Gulp\\\' every 3 mins or so and air bubble rushes up the pipe and settles in the top rad. From a previous post I was told that the hot water from the boiler is returning too quickly via the hot water cylinder and I should place a restrictor on to the pipe entering the cylinder.
My question is can anyone tell me exactly what sort of restrictor I should buy and if it\\\'s o.k to place the restrictor on the pipe exiting the cylinder as there is no room on the the pipe entering the cylinder.....diverter valve is 1 inch away from cylinder.
p.s the rads all heat up perfectly when the hot water is off. the problem only starts when the hot water cylinder calls for heat.
Many thanks for your help.
