DIYnot
Local | Network
   DIYnot > Forums
Local | Network
main medway automatic
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
btic
from United Kingdom
PostPosted: Tue Aug 15, 2006 11:01 am Reply with quote
I have a main medway automatic which supplies a shower through mixer taps. The hot water is ok through the normal taps but not through shower. Is the problem likely to be the diaphragm and if so is it easy to replace? Has anyone got MIs
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 825 times
PostPosted: Tue Aug 15, 2006 8:07 pm Reply with quote
MI's are available on the Baxi website Main belong Baxi. I know that because when I was trying to fix one and rang Baxi for service information the nice man said that they are definately on there but hard to find. I never did find them but they are there.
Failing that ask them to send you a copy.
Is it the diaphragm? Depends what flow rate from the other tap inspires it to light, then check with Baxi if that is correct, if not fit a diaphragm.
I'd sooner have a Brittony II to change the diaphragm on.
You'll probably knacker the two small copper pipes and will need a new seal which the pin slides through, and have to take the whole thing off and on a few times before you have it leak free again.
GOOD LUCK, horrible machines.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Tue Aug 15, 2006 8:37 pm Reply with quote
Here http://www.partsarena.com/baxi/
you will find all these:
Basic (Later Production) (GC No. 5247625)
Medway Super L (GC No. 5247641)
R (Late Production) (GC No. 5247628)
Super (GC No. 5247639)
Is the "Automatic" a different one?
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 63 times
PostPosted: Tue Aug 15, 2006 8:49 pm Reply with quote
Always thought the medway automatic was only for lpg?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Tue Aug 15, 2006 9:20 pm Reply with quote
Went into Identiffier and it looks like you're right Oilski. Automatic only listed for LPG. Parts Numbers for diaphragm etc are not same as any of the others I looked at.
Back to top
 Alert Moderators
superskanker
from United Kingdom
PostPosted: Tue Aug 15, 2006 10:24 pm Reply with quote
probably the shower thermostat then, assuming its a thermostatic shower
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3428 times
PostPosted: Tue Aug 15, 2006 10:36 pm Reply with quote
Clearly ( to me ) the flow rate through the shower is not sufficient to turn the water heater on.
Confirmation by measuring the flow rate through tap and then through shower.
Solution to either clean the holes in the shower head or drill them out to increase the flow rate.
Proper solution, measure flow rate and then change diaphragm if heater needs more than 2.5 li/min to turn on.
Tony Glazier
Back to top
 Alert Moderators
btic
from United Kingdom
PostPosted: Wed Aug 16, 2006 2:09 pm Reply with quote
The shower works off a mixer tap regulated by a governor on the cold feed. The same problem occured 6 months ago and I replaced the shower mixer and head which worked. The governor has also been replaced in the last few years. Hence everything between shower head and water heater are relatively new which seems to point to diaphragm unless mixer/governor have gone faulty
Back to top
 Alert Moderators
OllieN
from United Kingdom
PostPosted: Wed Aug 16, 2006 2:57 pm Reply with quote
Could it just be build up of limescale in the shower head restricting the flow (hence the new shower head fixed it 6 months ago)? Maybe just try descaling the head for a quick fix?
Sorry Tony, just read your post and you've already suggested this.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3428 times
PostPosted: Wed Aug 16, 2006 6:06 pm Reply with quote
I think that the further information may be a significant clue!
Can you adjust the outlet pressure on the regulator to significantly reduce it.
Tell us what this does.
We also need to know the water flow rate at which the heater turns on when just a hot tap is turned on.
Tony
PS Great minds think alike Ollie !
Back to top
 Alert Moderators
btic
from United Kingdom
PostPosted: Tue Oct 03, 2006 11:18 am Reply with quote
As an eplilogue:- finally the shower got too cold so I replaced the diaphragm. It was easier to take the unit off the wall and turn upside down to remove 8 screws to bottom plate of water regulator Everything seems to work ok now. Thanks to any contributors.
Back to top
 Alert Moderators
sasibhushanp
from United Kingdom
PostPosted: Wed Jan 03, 2007 12:15 pm Reply with quote
I have the Medway Super GC No 5247639 Gas fired water heater. I have the problem as 'btic' mentioned. I am not getting HOT water in the Shower.
Do you know any company who can do servicing this water heater in Middlesex Area? If so, please let me know their Website address as well as their contact telephone details.
Rgds,
Sasi
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Main Medway Automatic 3 2360 Sun Oct 09, 2005 8:11 am
Main Medway Super problem 40 2400 Sun Mar 01, 2009 5:49 pm
Main Medway Super Water Heater- little or big problem? 3 300 Wed Apr 18, 2012 1:57 pm
Main Super Medway 5 2000 Sun Oct 30, 2005 5:57 pm
Main Medway Super 5 1200 Tue Nov 06, 2007 3:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
