i have just got a new hob it has live 1 2 and three with two u shaped pins in the lives this leaves me wonderin where to put the electric cable the hob is a hc60 and the instructions are basic
You should find some copper U shaped links either within the rear of the cooker or in with the documentation. Your live feed to the cooker goes in L1 and the links are used between L1, L2 & L3
