DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
light permanently on
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 6:58 pm    Post Subject:
Reply with quote Thanks
Hi In my son's room he had an old 3 light ceiling spot light. One of the bulbs literally blew out of the holder and although I tried to replace it one of the three lights won't work - so as it was 20 years old, I bought a new 4 light spotlight. I wired the old red fron the ceiling into the brown of the light, then the old black from the ceiling to the blue of the light, then attached the earth to the earth on the light. When I switch the power back on, with the light switch off, the light comes on. When I try to switch the light switch on, the fuse blows. There are no visible wires touching. Any ideas ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:04 pm    Post Subject:
did you only have one cable coming out of the ceiling (red black and earth)
Back to top
 Alert Moderators
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:10 pm    Post Subject:
No - I had three reds all twisted together, three blacks twisted together and 2 earths twisted together.
Each of the three colours go into separate plastic junction boxes.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:12 pm    Post Subject:
no, bet you didnt, are you 100% thats how it was. usually all blacks together two of the red's together on red on its own with the live and neutral of your light fitting into blacks and the red on its own
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:14 pm    Post Subject:
one red on its own
Back to top
 Alert Moderators
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:20 pm    Post Subject:
I'm not 100% sure. Just say a little more about your last post as I reckon it must be that.
Any way I can tell which red is on its own (or doesn't it matter). It would help me if you could clarify, from the wires down from the ceiling, how they should be combined. Really appreciate your help.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
sorry mike one eye on football didnt quite read your post correctly,
all reds together two blacks together with neutral of your light fitting with other black to live of your light fitting (you should wrap some red tape around this to show it is the switched live return. when you are switching the wall switch you are putting a dead short accross live and neutral. you may have blown the switch and it may now require replacing
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:22 pm    Post Subject:
if you look in the refence section (third one down ) scroll down to see pic
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:26 pm    Post Subject:
you need to identify which is the cable going to the wall switch, if you can get above you may be able to trace it
Back to top
 Alert Moderators
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:27 pm    Post Subject:
one eye on the football here too. Crouch should have scored. So I have five wires (three reds and two blacks) to neutral and the other black to the live of the light fitting.
If I understand you right, does it matter which black ?
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:32 pm    Post Subject:
mike sorry no, three reds together in a connector block, two blacks in a connector block with the neutral of the light fitting and the last black in a connector block with the live of the light fitting. yes the single black must be the black of the cable going to the wall switch ( you should wrap some red tape around it to show it is the switched live return)
Back to top
 Alert Moderators
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:35 pm    Post Subject:
thats brilliant thanks - its too dark to work on now so I'll do it in the morning. Thanks a million for your help. Hope england win. If you have sky - Murray's beating Federer.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:36 pm    Post Subject:
no worries
paul
Back to top
 Alert Moderators
mikesimm
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:39 pm    Post Subject:
sorry Paul - one last thing - the three reds in a connector block - nothing from the light attached to it ?
Back to top
 Alert Moderators
fender
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 9:15 pm    Post Subject:
Try this..
Switch off lighting circuit. ( at the main board )
Separate all the blacks and make sure they are not touching anything or each other.
Turn power back on and see which black goes live / dead as you turn the light switch on and off. The one that does, connect to the live of your light. Put the other blacks back where they were and connect the N of your light to them.
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Light On Permanently 3 420 Thu Dec 13, 2007 7:39 pm
Permanently On Light 21 860 Thu Apr 06, 2006 10:21 am
rewired light - permanently on 19 540 Mon Aug 03, 2009 1:16 pm
turning pilot light off or leaving it permanently on? 2 160 Thu Sep 18, 2008 5:40 pm
Permanently on lights 5 340 Sun Mar 27, 2005 10:59 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
