DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
how to attach roughcast to mesh (no bricks behind)
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
HOUSEMARTIN
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 7:46 pm    Post Subject:
Reply with quote Thanks
Hi. We have a house built in 1932 and need to replace blown roughcast between the ground floor and 1st floor bay windows. Trouble is, the base render is fixed to steel mesh, with nothing behind it. The section above the ground floor window is okay as we removed the plaster inside and insulated last year, so it's solid. But the room above is not on our schedule to do for ages (can't afford to) so this section is going to remain uninsulated, and therefore not solid, for a while. How on earth am I going to get the render to stick? (And how on earth did they get it to stick in the first place - they must have mixed it with horsehair). I thought of putting a layer of hessian, or perhaps muslin as hessian might be too thick, on top of the mesh and the render will stick to that. What do you think?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dougalhouse
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 16, 2006 9:40 pm    Post Subject:
The render is mixed slightly stiffer than normal and applied to mesh. Not much sticks first time but whatever does is left to cure - 24 hrs or so. This usually provides a good enough key for a scratch coat.
Hope this puts your mind at rest!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Attach render to bring in line with extension. 4 560 Fri Apr 27, 2007 1:07 pm
Max Weight I can attach to a concrete block wall 2 260 Tue Mar 17, 2009 1:16 pm
Pebbledashing over roughcast 6 660 Wed Apr 11, 2007 2:44 pm
pebbledash/roughcast 3 1460 Wed Feb 07, 2007 1:47 pm
Roughcast rendering 3 3660 Fri Sep 22, 2006 7:46 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
