I hope someone can help me as my shower temperature is slowly driving me mad.
I moved into a property in March this year that has a potteron puma 80or 80e combi boiler (I forget which one), which is plumbed into mains water pressure and is at the end of the line of the cold water system.
Unfortunately since moving in we have had problems with the hot water, where it comes out scalding hot with no cold water and then as soon as the cold water tap is turned on the boiler switches off (just to the pilot light) and then I go from a scalding hot shower to a freezing cold shower. Even though we have no other appliances running or any other taps running.
We contacted a professional who said we need a non-return valve, which we duly fitted, but this did not make a difference.
After many hours learning about combi boilers and speaking to friends we believe we know what the problem is however we do not know how to solve it and I would be grateful for any help
We think the problem is that we turn on the hot water, which sends the cold water to the boiler, which pushes the diaphragm in the boiler and starts the boiler up and produces the hot water. But when cold water is requested in the bathroom, water is diverted to the bathroom this then drops the water pressure going to the combi boiler which thinks that it no longer require hot water and goes back to just the pilot light.
I have now been living with this for nearly 6 months and I would be grateful if anybody can suggest what I can do to over ride this problem so at last I can have a decent shower.
