hoover WDM 120 washer /dryer
17 Aug 2006
i have a hoover WDM120 washer/ dryer if you turn the programmer to any cycle it starts to fill with water then dumps it out again then fills up and so on . i have changed the programmer but it still the same .
You might start by checking the pressure switch. This detects when the water level is high enough. The pressure switch is on the left front when you are at the back of the machine, a bit hidden below the top. There is a long pipe that goes to the back of the drum and there is a plastic bit angled to the right if you remove the back panel. If you remove one of the plastic tighteners you can take the pipe off and if you blow into it you should hear two clicks.
I'm no expert - just spotted your problem whilst searching for an answer to my own - but I think this sounds like a case of siphoning. Had it happen a couple of years ago. Check that the drain hose from the machine is not pushed too far down the drain pipe. If is is siphoning it'll be problem solved. :D Good luck.
