Has any one else had any problems with the above mentioned bathroom extractor?
It has PIR,Timer and Humidity stat and is one of these slim line ones where the vents slowly open on power up.
Different modules are available depending on what you need it to do.
The problem is when it is wired to the diagram it continously runs even with the PIR covered up,the stat turned right down and the timer also right down.
The module has been replaced today with a new one and the problem is the same.
I have live,switched live and neutral and moving the switched live(yellow) over to the perminent terminal on the fan switches it on and off via the light switch as you would expect.
Any ideas as surely a second module can`t have the same fault as the original???
