DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Help with ceiling rose
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
meeshy3000
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 19, 2006 8:00 am    Post Subject:
Reply with quote Thanks
I am replacing an old ceiling spotlight on the landing with a ceiling rose. There are 4 red wires and 4 black wires coming from the ceiling. They are not taped together. I have no idea how to attach the new ceiling rose to these wires, can someone please help. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Aug 19, 2006 8:06 am    Post Subject:
You first need to identify which of the "two core cables" (red and black) goes to the switch - if you can do this by tacing it out in the loft, do that......otherwise you will need to use a multimeter or similar to test between red and black while someone switches the switch.....with the power OFF.
Do any other lights operate with the same switch?
Back to top
 Alert Moderators
meeshy3000
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 19, 2006 8:17 am    Post Subject:
Hi
Thanks for replying. No only 1 light operates, but has 2 switches one upstairs and one downstairs. All the red cables were wired into 1 connector, but I am not sure about the black wires as they came loose when I took down the old spotlight- but it looks like 3 of the 4 black wires were wired into 1 connector and the other black wire a separate connector
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Aug 19, 2006 8:20 am    Post Subject:
OK, the reds stay in the connector on their own.
The earths all go to earth.
The three blacks that where together go to neutral.
The black that was on it's own is returning from the switch, should have a bit of red sleeve or red tape on it, and connects to the lights live terminal.
Back to top
 Alert Moderators
meeshy3000
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 19, 2006 8:23 am    Post Subject:
So in the ceiling rose do I just put them into the connectors as they are and not separate them? thanks
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Aug 19, 2006 8:25 am    Post Subject:
Yes, put all reds in the center loop terminal.
put all neutral blacks into the neutral terminal with the blue flex
put the switched live black into the live terminal with brown flex.
As you have four cables, rather than three, you will need to share terminals in the rose for the loop/neutral.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Aug 19, 2006 8:26 am    Post Subject:
Like that!
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Aug 19, 2006 8:27 am    Post Subject:
[secure becomes a little impatient with yet another DIY'er who has failed to note where the wires go in a light fitting...... icon_rolleyes.gif]
__________________
Back to top
 Alert Moderators
meeshy3000
from United Kingdom
Thanked: 0 times
Thank you so much for your help- here I go.......
Meeshy 3000
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
ceiling rose problem 4 1920 Thu Jul 13, 2006 9:54 am
Ceiling rose - again.. (updated with picture) 9 580 Sun Jun 25, 2006 3:59 pm
Metal ceiling rose and light switch metal face plate 9 3040 Fri Jul 14, 2006 2:16 pm
New ceiling rose 4 320 Fri Jul 21, 2006 7:08 pm
black pendant (ceiling rose?), long drop pendant 9 1440 Fri Jun 27, 2008 1:14 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
