- Joined
- 25 Jan 2004
- Messages
- 53
- Reaction score
- 0
- Country
Is it possible to power a single oven and a combination oven off an existing single radial (I presume) circuit (currently powering a double oven)? Both appliances have a max power rating of 3.6 kW. I make it that each would draw 15A max, so both together would draw 30A max; would this work? Bearing in mind also that the single oven will be moved to the other side of the kitchen (approx 2.5m), so a feed will need to be taken across there, with the combi oven on the side of the existing double oven. How would this be wired up? Would they be individually fused?
An electrician I had around yesterday said he could get away without using the existing double oven circuit for the new single oven on the other side of the kitchen, using the ring circuit in some way... would this be possible / safe?
Many many thanks!!
Michael Brewer
Many many thanks!!
Michael Brewer
