DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch Dishwasher Pump does not stop
This topic originated from the How to page called Dishwasher Troubleshooting
Click here to return to the page called Dishwasher Troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Tig
from United Kingdom
PostPosted: Sun Aug 20, 2006 5:59 pm Reply with quote
When I turn the machine on it will pump out the remainder of the water but does no more. It does not stop pumping and no water comes in. Please help.
E No is SGS 4332 GB
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Sun Aug 20, 2006 8:05 pm Reply with quote
Anti flood device has been tripped. Possibly a leak into the base or overfoaming leading to water in the base.
Back to top
 Alert Moderators
Tig
from United Kingdom
PostPosted: Wed Aug 23, 2006 4:29 pm Reply with quote
You are correct, but how do I get access to the "drip tray" to empty it? There are two T20 screws one each side but the just loosen the part that contains the front legs. In the end I tipped it on it's side and water came out and now it works!!
So the question is how to gain access to the tray and to check for leaks.
Many thanks
Tig
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Wed Aug 23, 2006 6:56 pm Reply with quote
Big job, door has to come off and tub too.
Get a large syringe and some tubing, easiest way to empty it
Back to top
 Alert Moderators
Tig
from United Kingdom
PostPosted: Wed Aug 30, 2006 5:34 pm Reply with quote
Thanks, I have now found the leak.
There is a very small hole in the bottom of the stainless steel tub. Do you know of any glues or compounds that could be used and would stand up to the washing and temperatures?
Cheers
Tig
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Wed Aug 30, 2006 6:27 pm Reply with quote
If you can get to the underside/rear of the hole then petropatch (stuff for patching petrol tanks) is ideal.
Back to top
 Alert Moderators
Tig
from United Kingdom
PostPosted: Sat Sep 02, 2006 8:32 am Reply with quote
Thanks for the tip, but unfortunatly it is (almost) impossible to get to the underside without taking every thing to pieces. I shall write to "Loctite" to see if they have a glue that will do the job.
Cheers
Tig
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Sat Sep 02, 2006 9:15 am Reply with quote
To patch from the inside Bosch use solder.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Neff / Bosch Dishwasher stop/start/stop/start..... 2 80 Mon Mar 28, 2011 12:03 am
Bosch Dishwasher won't stop pumping. 2 120 Tue Jan 24, 2012 9:06 pm
BOSCH LOGIXX STOP HALF CYCLE 2 1040 Sun Sep 24, 2006 1:52 pm
Bosch washing machine - won't stop draining 8 1200 Thu Sep 24, 2009 7:04 pm
Hotpoint Dishwasher wont stop washing 3 2920 Mon Dec 26, 2005 11:08 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
