Typeone
Joined: 20 Aug 2006 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Sun Aug 20, 2006 8:39 pm Post Subject: Fluorescent Light |
Hi.
I have mains power running to my garage via a semi permanente extension cable. I wish to add lighting in the form of a 240V IP65(?) 1500mm Fluorescent Light. Like this
Is it possible to run this from the mains extension via a transformer? or can i just plug it in?
In case you were wondering..... i know nothing abouy electrics.
Thanks.
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Typeone
Posted: Sun Aug 20, 2006 8:47 pm Post Subject: |
So it just plugs in then?
Should have mentioned. The extension cable is run inside some PVC conduit and fixed to the wall. |
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Sun Aug 20, 2006 9:26 pm Post Subject: |
does this conduit go underground anywhere? |
Typeone
Posted: Mon Aug 21, 2006 3:21 pm Post Subject: |
No, its all above ground. |
plugwash
Posted: Mon Aug 21, 2006 3:25 pm Post Subject: |
not so bad then, no digging risk (which is the main reason for using SWA)
you should just be able to fit a flex to your light though and plug it in, remember to do something to restrain the flex where it comes out though (compression glands work very well for restraining flex that comes out of the 20mm knockouts you see on fittings intendeded for fixed wiring) |
Typeone
Posted: Mon Aug 21, 2006 3:46 pm Post Subject: |
Thats good.
Will pick up some compression glands.
Thanks for your help. |
