DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Moving a light switch ( adding socket)
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
saracen
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 12:30 pm    Post Subject:
Reply with quote Thanks
My outside light switch needs to be moved approx 2 feet, its present location is next to the consumer unit and i would like to move it to outside the consumer unit cupboard for easier access.
1. The cable from the outside light to the switch ( double switch) will need to be lengthened, can i join additional cable onto it without it causing any probs? ( 2 foot)
( cable from switch to CU is easy enough to replace)
2. I'd like to have an electrical socket near to where the light switch will be placed, can a single ( or double) socket be wired into the light switch ?
Thanks for your time.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Aug 21, 2006 12:36 pm    Post Subject:
You can extend your lighting cables by using a junction box, as long as that JB is accessible for inspection & testing purposes.
If it is easy to replace the cables so that there are no joins, do that.
You cannot wire a socket from a lighting circuit. Even if you could, there is not always a neutral at the switch position.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
saracen
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 12:46 pm    Post Subject:
Thanks for your reply, To replace the cable from the outside light to the switch will be bummer of a task BUT not impossible, will try it initially but if no joy will go for the JB option.
cheers.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Moving plug socket or adding a spur 3 180 Thu Sep 03, 2009 7:39 am
moving a picture light and adding another one to it 3 160 Sat Apr 18, 2009 6:34 pm
Moving socket sideways 6 340 Tue Apr 08, 2008 10:51 pm
Moving socket in plasterboard wall 4 1320 Mon Oct 23, 2006 3:21 am
Moving a socket 2 3820 Sun Nov 05, 2006 2:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
