flowertot
Joined: 21 Aug 2006 Posts: 1 Location: Berkshire, United Kingdom Thanked: 0 times
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Mon Aug 21, 2006 12:58 pm Post Subject: |
Methylated spririts will soften biro ink. Rub it with some kitchen roll wetted with meths and the ink should transfer to the paper (otherwise it will just smear over the door). A microfibre cloth might also do it. Use rubber or vinyl gloves as it will dry the skin.
Try not to use an abrasive or cream cleaner as you will erode the paint finish.
If it is very slow, mix washing-up liquid with meths to thicken it so it does not run straight off and evaporate, and apply it with a nylon washing-up brush. You can use the same method for sticky label marks. |
sm1thson
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Wed Aug 23, 2006 8:56 am Post Subject: |
alchohol works -just lifted a big biro stain off my new sofa with alchohol gell, although the stain on the painted door handle was more stubban so i dont know how well it will work on the fridge. |
