DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
electric meter faults
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
nor
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 9:42 pm    Post Subject:
Reply with quote Thanks
can anybody tell me if it is normal for an electric meter to run on after the consumer unit is switched off, (domestic).Manweb say this is normal and a check meter they fitted has confirmed (they say) that my own meter is OK. my meter still turns for at least 40 minutes after consumer unit is switched off.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Aug 21, 2006 9:47 pm    Post Subject:
in this 40 minutes, how much electricity is recorded by the meter?
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 9:49 pm    Post Subject:
no way something must be wrong have you only got one consumerunit connected
Back to top
 Alert Moderators
nor
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 9:52 pm    Post Subject:
meter moves very slowly and records about 3 or 4 segments
Back to top
 Alert Moderators
nor
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 9:53 pm    Post Subject:
i have two consumer units but both switched off
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Aug 21, 2006 9:56 pm    Post Subject:
Re: meter moves very slowly and records about 3 or 4 segment
What is a segment, and what does it cost?
(use the "reply" button)
Back to top
 Alert Moderators
nor
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 21, 2006 10:05 pm    Post Subject:
meter disc is divide into segments or lines which can be seen when rotating. no idea how much power is being used but probably very little
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Aug 22, 2006 2:39 pm    Post Subject:
3 or 4 segments is probably 0.0000001 pence, if that. Look at your meter, it will say "__ turns per kwh". This refers to the number of times that disc spins right round before one KWh is consumed. One KWh costs about 9 pence.
Mine says 200r/Kwh, down next to the meter's serial number.
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 22, 2006 6:37 pm    Post Subject:
just read post again, 40 minutes! you watched it for 40 minutes and it move 5mm. wasn't there any paint drying somewhere
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
underground swa faults 3 240 Sat Jan 26, 2008 6:55 pm
Sodium outside street lamp faults HELP 17 700 Mon Feb 18, 2008 6:12 am
Neutral-Earth faults 6 420 Thu Aug 16, 2007 8:05 pm
testing for earth faults 16 1040 Wed Aug 15, 2007 5:52 pm
Very Odd Alarm Faults 10 600 Mon Oct 10, 2005 7:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
