Over freezing freezer
22 Aug 2006
London
Have a fridge/freezer zanussi model no ZK53/37R which is over freezing in the freezer especially around the top drawer. Is this caused by a defective door seal and if so how easy is it to change. Had thermostat changed a few months back but problem has come back. Any thoughts appreicated.
Thornton
Probably find it's a bonded seal which means a new door.
If when you try to open the door you feel resistance then it's not the door seal as you've got a vacuum. Check the door seal for holes and splits, also check that it's sealing all round the aperture. Also check that the door hasn't dropped.
Does "over freezing" mean too cold?
Or do you mean excessive frost deposits?
JohnD
As John asks, its not that now the weather has warmed up the t/stat needs adjusting.?
Over freezing is when ice builds up on the pipe OUTSIDE the unit.
I think you probably have a poor door seal. It may be that the frost build up is stopping the door closing. Try defrosting & starting again.
By overfreezing i mean ice build up around the top drawer. It is not too excessive but makes it hard to open the top drawer.I think the thermostat is turned down low.One problem we had was that when they tiled the kitchen floor and put back the freezer the space under the cupboard was very tight and they wedged the freezer in. When i raised the cupboard up the freezer moved up a fraction so maybe there was a bit of distortion of the freezer.
Thornton
