Hi all, I am installing a small sink with a monobloc mixer tap. The instructions say that the hot and cold supplies should be of equal pressure; ie: both from tanks, and not using the cold from the rising main, and that double check valves should be installed close to the tap. Firstly is this correct and secondly are double check valves service valves as well.
any advice appreciated greatly!
