Need help choosing tap
29 Jun 2006
Birmingham
Hi can anyone give me advice on what type of kitchen tap to go for if I'm not sure on my water pressure? My cold water supply is fed from the mains and NOT from a tank in the oft, and the hot comes from a combi boiler next to the sink.
I see there are many taps that specify pressure requirements such as 1.0 bar or 0.5 bar but I'm not sure what ours is. Currently we have a mixer tap with separate hot & cold handles, although I want to replace it for a tower type single handle tap.
All kitchen taps are mains fed as they are drinking water outlets.
From what you say the hot is also mains fed via the combi so your pressure should be sufficient to install any style taps you wish.
You can get an idea of flow rate by seeing how long it takes to fill up a litre container with your cold tap on full.
Pete
Thanks Pete, so what sort of times should I be getting to fill up a litre bottle to estimate my flow rate?
try putting a bucket under a running tap
count to six
remove bucket
measure quantity of water in aforementioned bucket (henceforth to be know as the "bucket")
times that amount by ten and viola you will have your flow rate
