Hi
I moved into a new build flat 5 years ago & one of my CH radiators has never worked. I have bled the radiator but no change. I have gas fired CH with a Baxi wall mounted powered flue condensing boiler.
Any ideas?
check both valves are opened and close all other radiators (one valve will do), this will confirm if there is a blockage or if sytsem is unbalnced etc.. depending on wheather it gets hot or not.
