highbury44
Joined: 25 Aug 2006 Posts: 12 Location: Northumberland, United Kingdom Thanked: 0 times
Posted: Fri Aug 25, 2006 11:03 am Post Subject: laying parquet flooring |
Hi Iam preparing to lay a parquet floor in my hallway using reclaim Iroko parquet blocks and would like some advise.The problem i have is half the hall is concrete and half the original victorian floor boards all on the same level.Can i lay the blocks as it is or would i have to lay plywood on the whole of the hallway?(Not keen on this as it raises the floor even higher) |
WoodYouLike
Joined: 14 Nov 2004 Posts: 6348 Location: Kent, United Kingdom Thanked: 29 times
Posted: Fri Aug 25, 2006 11:10 am Post Subject: |
With any wooden floor you install you have to have ONE type of underfloor. So yes, plywood/chipboard on the whole lot __________________ You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA. |
highbury44
Posted: Fri Aug 25, 2006 4:37 pm Post Subject: laving parquet flooring |
Thankyou for your reply.What is the min thickness of board i could use? |
WoodYouLike
Posted: Sat Aug 26, 2006 8:30 am Post Subject: |
6mm should do it __________________ You buy quality, we'll advise. You buy rubbish, we won't!
highbury44
Posted: Mon Aug 28, 2006 9:04 pm Post Subject: |
Hi .again thanks for the reply.How do i fix the Plywood to the concrete floor? |
