DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Loss of water pressure
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
PlymWS
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 25, 2006 2:10 pm    Post Subject:
Reply with quote Thanks
I've just renewed the main stopcock and cold water pipe to my bathroom. The pipe that runs upstairs to the bathroom also has an inline 90 degree valve on it so I can isolate the supply to the bathroom shoud I need to.
I have opened the stopcock and can hear water passing past it but when I open the 90 degree valve, I get no pressure upstairs at all.
Both valves were bought new so do I need to setup the stopcock or similar. If not, all I can think of is that the inline valve is dropping the pressure dure to the reduction in bore at the globe valve sufficiently to reduce the pressure passing through the valve to nothing.
The length of pipe in question is about 3 metres long and runs vertically from after the stopcock straight through thre ceiling to the bathroom.
Can someone confirm, or indeed deny, my suspicions as I don't want to go ripping valves out just yet in case they aren't the problem. On the other hand, I need a shower so need the water back soon !!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Fri Aug 25, 2006 2:40 pm    Post Subject:
Is the stopcock the right way round?
Back to top
 Alert Moderators
PlymWS
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 25, 2006 2:44 pm    Post Subject:
Yes, the arrows on both the stopcock and the inline valve are pointing in the direction of flow
EDIT: Turns out the brand new stop cock was faulty. The valve had stuck on the seat.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Loss of water pressure - with a difference (maybe) 4 440 Mon Oct 15, 2007 8:34 am
Loss of Water Pressure Through Combi Boiler 2 680 Mon Sep 03, 2007 11:30 am
Loss of hot water pressure on a mixer shower 5 1500 Sat Jul 19, 2008 6:57 pm
Water pressure loss 2 240 Sun Sep 07, 2008 12:47 pm
Worcester 24i RSF - loss of hot water pressure 3 360 Thu Oct 13, 2005 1:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
