Risk of overheating a TV
7 Jun 2005
Surrey
I want to put a portable TV in our conservatory, but as it gets a lot of sunlight, I am concerned about the risk of overheating it or causing a fire.
It is very hard to find a spot where it is not possible for it to be in the sunlight. It is a CRT television, as opposed to LCD or plasma. Is there any less danger of overheating with LCD or plasma? Indeed, is there any risk of overheating a CRT TV at all?
Our conservatory glass is pilkington K argos filled, and the roof is opal translucent polycarbonate.
Yes, I had considered that, but if the window is behind the TV, the screen will not be facing towards the sun - in this case I would just be concerned about the possiblity of it overheating from the back.
I am sure your fears are unfounded if the portable you have is new or fairly modern they consume quite low levels of power to start with and providing the cabinet vents are not covered there should be no problem with ventilation. All tv,s including portable tv,s are now fitted with power supplies which monitor overheating, overcurrent, and overvoltage and if any of these rise the power unit simply closes down as if switched into standby.That is why modern tv,s catching fire is now extremely rare these days.
