Netaheat Wiring Query
28 Jan 2006
London
Hi All
I have to quote to replace a Netaheat (yay!) but cannot remember the original wiring specs and dont have the manual.
I assume that it has a permanent live, but does the 16-22 include a pump overrun relay? if not, I'm going to have problems with the wiring.
Thanks in advance.
Dont assume that it has been wired up though !!!
Yes, he means that the pump could have been wired direct from the wiring centre and bypassed the overrun relay. With the netaheats CI heat exchanger it wouldn't have caused too much of a problem.
It will cause me massive problems if he is right though.
Put a pipe stat on the pipe by the pump then. Wire it so the pump is powered from SL when the pipe's cold, and mains when the pipe's hot.
That's what the boiler would do.
