Joined: 28 Jan 2004 Posts: 5 Location: United Kingdom Thanked: 0 times
Posted: Wed Jan 28, 2004 2:33 pm Post Subject:
insulating the shed
I am looking to insulate a large shed / workshop so my wife can use it all year round (she is a watercolour artist). I was thinking of putting up battons on wall and floor, using 1" polystynene sheets on the floor, and topped with 18mm chipboard. On the walls and roof I was going to use loft insulation roll then plasterboard on top, (with hardboard on the roof). It would then be wired and lit by a proper electrician.
Can anyone see any problems with this or have any other ideas or suggestions.
Thank you
Posted: Sat Jan 31, 2004 8:36 am Post Subject:
shed insulation
Thank you both for your replies.
The roof will just be a sheet of ply (I think) with felt on top. Its going to a a commercaily bought shed. What I was thinking was to put battons on the underside putting up the insulation and then nailing normal sheets of hardboard on top to keep it in place. The polystyrene, I was going to use 2' x 8' x 1" sheets I saw at Wickes.
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Sat Jan 31, 2004 11:47 pm Post Subject:
See this. Bearing in mind this is for soffit underneath,if you have no soffit but just the fascia,you can get round it but need more details on the type of fascia you have got.
Joined: 16 Sep 2003 Posts: 7790 Location: United Kingdom Thanked: 7 times
Posted: Sun Feb 01, 2004 7:24 am Post Subject:
I would use the blue polystyrene (one brand name is Styrofoam. This is high density and has a spec (if I remember correctly) of 2% compression for some tons per sq metre. The wickes stuff will not resist loads like filing cabinets and will let the floor boards gradually sag. I seem to remember the blue is closed cell, but I could be wrong.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
