Just had camry5 combi fitted ,new pipe work and seven new double rad`s,room stat, 7trv`s and programmer. Problem all rad`s seem hot at top and extending down but bottoms are cold.How can I overcome this problem.Havn`t tried bleeding rad`s not sure with sealed system.
mebbe it would be worth asking them, as sludge usually manifests itself with cold spots on rads, and as air is lighter than H2O it usually causes the top of the rad to go cold
