DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Radiator connection leaking
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
JSL
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 03, 2006 7:36 pm    Post Subject:
Reply with quote Thanks
Hi, I\\\'ve just fitted a AGL Towel Rail in place of the existing Rad in my bathroom using a new Drayton TRV4. The problem I have is that where the valve connector goes into the Towel Rail will not seal! I have removed and refitted 6 times using various quantities of PTFE tape and Green Boss but every time there is a slight leak. The thread appears good on both the connector and towel rail, and it hasn\\\'t been cross threaded! It looks to be a tapered thead (can anyone confirm this) so \\\'ought\\\' to seal when tightened. Any suggestions for my next attempt? Thanks in advance
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Gasguru
from United Kingdom
Thanked: 17 times
PostPosted: Sun Sep 03, 2006 7:47 pm    Post Subject:
Most towel radiators are badly designed and often have only a few threads, getting them watertight is a common problem. icon_sad.gif
Wind the PTFE to form a taper, in this way as the tail is screwed in the PTFE will form a "washer" as it backs up on the thread. Don't go too mad tightening it up as you may strip the threads.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sun Sep 03, 2006 8:48 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaking top connection of heating coil on hot water cylinder 8 800 Tue Jul 03, 2007 8:38 am
Leaking connection between plastic thread and copper pipe 37 1140 Tue Mar 31, 2009 7:43 pm
leaking cistern/flushpipe connection 11 360 Wed Jun 04, 2008 12:10 pm
Leaking connection tap to mains 2 320 Tue Apr 10, 2007 8:06 am
Leaking water connection on new toilet 2 580 Sat Mar 04, 2006 5:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
