DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
squeaky floorboards
This topic originated from the How to page called Stopping creaking floorboards
Click here to return to the page called Stopping creaking floorboards.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
jmh
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 04, 2006 9:16 pm    Post Subject:
squeaky floorboards
Reply with quote Thanks
Sorry, I know lots of other people have posted about this but I'm still unsure how to proceed. I live in a 1930s block of flats. I'm on the second floor. When I moved in 10 months ago I immediately took up the carpet in my lounge and bedroom and sanded the floorboards with a sanding machine. From that moment on I have had a series of complaints from the lady living beneath me. She finds the creaking/squeaking floorboards unbearable and insists that there was no problem before I took up the carpet and sanded the floor. She is becoming quite manacing and demanding to know what I intend to do about it. I have tried putting down a big, thick rug with thick underlay but she reckons that it's hardly made any difference. The floorboards in my lounge are a lovely cherry oak wood, about 7cm wide and very close to each other, practically touching in some places. I would follow the advice that has already been posted about removing the nails and putting screws in instead but the nails are knocked right in and I have no idea how I'd pull them out without destroying the floorboards. In my bedroom the floorboards are pine and about double the width with gaps inbetween but they still creak like hell. Talcum powder is unlikely to help because of the big gaps. The boards are slightly warped and I think that is causing the problem.Is there any way of solving the problem of warped floorboards?
I'd be grateful for any advice you can give me as it's only a matter of time before she makes an official complaint (again).
Many thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
simon_t
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 04, 2006 10:37 pm    Post Subject:
I recently read somewhere, not sure where icon_eek.gif god I'm getting old now!, of a guy who put a damp proof membrane between the joists and the floor boards, this stopped the creaking at it offered a form of 'lubrication' to the mated surfaces. It does mean lifting the boards however. If care is taken then there is a good chance you can lift them without too much trouble. Though you will need to remove the skirting and possibly some plaster if it goes all the way to the floor.
Hmm, it all seemed like good advice until I read it again...oh well...try playing music so loud the old coot forgets about the floor boards, try Slayer icon_twisted.gif
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Tue Sep 05, 2006 7:12 am    Post Subject:
Leave the nails in and add screws. 50mm x 5mm will be fine. Screw near the nails so you're sure of hitting a joist and also the nails should be well clear of any pipes or cables, so if you screw there you should be ok.
It is gonna ruin the look if your floor though (unless you fill over the screws).
__________________
If I'm curt with you it's because time is a factor. The Wolf.
Back to top
 Alert Moderators
splinter
from Antarctica
Thanked: 0 times
PostPosted: Tue Sep 05, 2006 2:17 pm    Post Subject:
I see the only solution is go along the lines simont has already mentioned other than that cover the floor in bubble wrap icon_smile.gif
Back to top
 Alert Moderators
jmh
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 05, 2006 6:33 pm    Post Subject:
creaky floorboards
Thanks for replying so quickly! I read somewhere on on this forum that even screwing down the floorboards doesn't always stop the creaking. So it looks like I'm going to have to take Simon's advice. My floorboards do go right up to the edge of the room, under the skirting. So I guess I'm going to have to remove the skirting to lift them. This is going to be a big job. There's an added complication in my bedroom - I've recently installed floor to ceiling wardrobes from IKEA right across one wall. However, the floorboards are parallel (rather than perpendicular) to the long edge of the wardrobes. About 5 and a half boards are hidden underneath. Do you think I need to dismantle the wardrobes (huge job)? Or can I get away with working up to the edge of them and not bothering with the floorboards that are already underneath?
I like the idea of putting a membrane-type layer down between the joists and the boards. Could you advise further on what sort of material this is and where I'd get it?
Many thanks.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Tue Sep 05, 2006 7:25 pm    Post Subject:
You've gotta be out of your mind taking the boards up. Usually the squeaking is due to the boards rubbing against the nails that have worked loose. If you screw them down I'm sure you'll notice a big difference.
__________________
Back to top
 Alert Moderators
splinter
from Antarctica
Thanked: 0 times
PostPosted: Tue Sep 05, 2006 7:41 pm    Post Subject:
Wellafter my first reply and because of the problems with taking up the floor,I do think like gcol said try screwing the boards down first.I wouldn't like the responsibilty of giving advice that could give you unecessary work and aggro icon_redface.gif
It might even help a bit if you punch the nails in a bit deeper with a nail punch and hammer
Back to top
 Alert Moderators
stonepimp
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 17, 2006 7:08 am    Post Subject:
Stonepimp -
Please read the Forum Rules
Mod Rupert
Back to top
 Alert Moderators
Fulham Steve
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 07, 2007 9:49 am    Post Subject:
Hi.
I also bought a flat on the top floor (3rd) which had the same problem.
I put some wedges under the skirting boards and put some no nails in it and then screwed some 2" screws right next to the nails and although not stopping the problem 100% it improved it so much and don't mind getting up in the night for a wee any more.
Make sure you check for pipes and electrical wires you can buy a tool for this (not sure what it is called).
Good luck and all the best
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
squeaky floorboards 7 6060 Sun Oct 28, 2007 1:35 pm
squeaky floorboards and fitted carpets 3 1480 Sun May 09, 2004 11:53 pm
Squeaky stairs 3 980 Thu Dec 14, 2006 4:29 pm
Squeaky floors are driving us mad! 4 980 Sun Jan 04, 2009 6:33 pm
Squeaky floor boards 3 1020 Wed Feb 06, 2008 12:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
