DIYnot
Local | Network
   DIYnot > Forums
Local | Network
STOP TAP LEAKING
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
madonnafan
from United Kingdom
PostPosted: Thu Sep 07, 2006 11:03 am Reply with quote
Turned stop tap off about 1 hour ago to replace tap on bathroom sink.
Turned water back on but now my STOP TAP is dripping/leaking at a rate of 1 pint in 3-4 mins (I have a pint jug under it so thats how I know!)
Not done the obvious (which is to turn it off) as my washing machine is running but I will when its finished!
It also gave me a chance to realise how much is dripping.
Seems like it will never stop!
It has happened before when I had to turn on/off the STOP TAP but only 1 drip every 30-60 seconds!
It then seemed to sort itself out!
Any ideas guys?!
Sharon
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1499 times
PostPosted: Thu Sep 07, 2006 11:07 am Reply with quote
Buy some spanners.
You will see two small nuts under the T-handle. Tighten the smaller one just a fraction.
Meanwhile, have a look round to see if there is an additional stop-cock in the front garden or in the pavement (it will be useful if you need a new stopcock fitting later).
Does yours look like newish brass, or is it old and black?
Back to top
 Alert Moderators
stewski
from United Kingdom
PostPosted: Thu Sep 07, 2006 11:24 am Reply with quote
phone the local water company, we had to do this with ours.
they may be able to direct you over the phone to the likely location of your external stop cock.
find it, you will probably also need a tool to both lever it open and reach down the the tap (which is likely to be to far/stubby to turn by hand) you can probably pick one up at a local plumbers merchants, maybe they'll even lend you one....
Once you can switch off the external stop cock you can start playing around with fixing/replacing the internal one...
Back to top
 Alert Moderators
stewski
from United Kingdom
PostPosted: Thu Sep 07, 2006 11:28 am Reply with quote
also for future reference.
when replacing a tap if your plumbings been done well there will be an isolator valve before connection to the tap (it usually has a flat headed screw head in the middle of it) this can isolate the supply to the individual tap (turn it 90 degrees), so you dont need to monkey around with the main stop tap.
Back to top
 Alert Moderators
waynes
from United Kingdom
PostPosted: Thu Sep 07, 2006 11:30 am Reply with quote
be warned that yours may be like ours, the outside stop cock turns off half the street! (7 houses)
not too mention the wildlife that had made its home around the stoptap....
Back to top
 Alert Moderators
madonnafan
from United Kingdom
PostPosted: Thu Sep 07, 2006 1:24 pm Reply with quote
the stop cock has been painted over a dozen times but the tap end looks a dirty brass colour rather than black.
It will have been put in when houses were built in 50's!
I will try tighten things n see how it goes.
As my tap handle is on the side,rather than at the top I assume you mean the nuts there as that makes sense!
I have spanners will get on with summat.
4 kids home soon and no water...not good!!
Cheers,I'll let you kno how I get on!
Sharon[/img]
Back to top
 Alert Moderators
madonnafan
from United Kingdom
PostPosted: Thu Sep 07, 2006 1:37 pm Reply with quote
chipped the paint off,tightened the nut!
ANOTHER JOB WELL DONE!
Cheers!!!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1499 times
PostPosted: Thu Sep 07, 2006 1:41 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Kitchen Mono Mixer Tap, wont stop leaking may need new part 7 2080 Sat May 29, 2010 12:06 pm
Leaking Stop Cock (part deaux) 4 680 Tue Feb 21, 2006 9:24 pm
How do i stop a leaking exterior pipe 13 260 Tue Sep 28, 2010 1:43 pm
Best way to stop leaking valve. 15 1120 Mon Oct 20, 2008 7:30 pm
Help mains stop tap leaking from bottom compression joint 9 180 Fri Apr 19, 2013 10:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
