I have been reading with interest the many postings about cooker circuits, and whether or not these should be used for anything else. If I understand what I've read, I would summarise as:
1) cooker circuits are best used only for cookers, however,
2) there is a provision in the relevant regs for an additional 'point', e.g. the 3pin socket often found on cooker isolation switches.
3) as an alternative to the combined 'cooker switch and socket' arrangement, it is permissible to have a single spur off the cooker circuit, as long as a) it runs through a suitably rated FCU and b) the spur is no longer than 300mm.
4) There seems to be mixed views on whether the same rated cable needs to be used for a) the whole spur, b) just up to the FCU, c) not at all.
Assimilating the above (rightly or wrongly) I have just wired in a spur to my cooker circuit. The circuit is currently wired in 6mm2, and has a 30amp fuse on the CU. I have thus used 30amp connector block to break into the line and spur off to a suitably-fused switched FCU which will run the extractor hood. The only unusual thing about the way I've done it is that I've used a deep, single-gang box to contain both the connector block and the switched FCU. In other words, from the surface it looks like a normal FCU, but it actually contains a very short spur and the cooker circuit continues on to the cooker.
I've done a rather poor diagram, which may or may not help to illustrate what I've done, but I'm having trouble uploading it, watch this space...
Anyway, any thoughts on the safeness, conformity of this arrangement would be appreciated.
