Rewire order (kitchen first)
  • Thread starter NotSureAboutDIY
  • Start date
N
NotSureAboutDIY
Hi All
Im looking at getting my house rewired (current job is poor) its a 3 bed terrace from around 62, it has floorboards on first floor, cavity breeze block walls, kitchen at fron living room at back stairs seperate the 2.
my question is how feasible/easy is it to do the kitchen first, then the rest of the place a few weeks later?
with part p etc is it legal for electrician to work on an install thats not within regulation without replacing all incorrect wiring?
Its certainly possible, but will probably cost a bit more than doing it all in one go, though kitchen and rest of house is probably most logical split if its going to be split. I'd install separate circuits for the kitchen if I was doing this way I guess, on the whole this would be the case anyway, with the exception of the lights, so no big difference there
Thats an interesting question, and the answer is it depends on what work is being done, who you ask, etc. I'd suggest in your case most electricians wouldn't have a problem, just fit a new board, install new main bonding from it (even if it goes into rooms other than the kitchen), feed old board from 50A breaker on new board, remove and bypass kitchen parts of old circuits, install new kitchen circuits, then he can come back a bit later and install new circuits elsewhere from the new board and then remove the old board. Note, please that part P hasn't changed anything with regard to the question except made things a bit more traceable and people more accountable, and minor 'rule-breaking' that even decent electricians might have done before (like testing an installation but not filling out an EIC) happen less now
cheers adam for a straight answer, shame you're not in brum!
Ive got a question on another thread about counter top trunking.
do you know of any such solutions for kitchens
also is surface mounted trunking within kitchens still OK?
I know its ugly but due to cabinet layout it should be well hidden...
I'm not yet qualified or registered either... (sorry, my writing style might have mis-led you slightly :oops: )
Not sure how muchit costs, but you can certainly still get such a thing, not sure there are any special products for kitchens or even what exactly you be looking for if you wanted a 'kitchen version'
It'll be ok with the electrician and the building inspector, but what about the kitchen designer or the wife?... :LOL:
Ok, A nice way to do a kitchen ring final circuit would probably be just trunk it around on the wall just below the countertop level go vertically a small distance where-ever there is an outlet
