DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cable size calculation of allumunium cable
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
saha_malay
from India
Thanked: 0 times
PostPosted: Fri Sep 08, 2006 10:34 am    Post Subject:
Reply with quote Thanks
current capacity of allumunium cable of different sqmm at 40degree C ambient temperature.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Sep 08, 2006 3:49 pm    Post Subject:
Can you rephrase that?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Fri Sep 08, 2006 3:57 pm    Post Subject:
There are charts for the current ratings of aluminium conductors in appendix 4 of bs7671 which give them a current rating at 30 deg C. To find its rating at 40 degrees all we need to do is multiply it by a de-rating factor for 40 deg C. I don't know about india though.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Sep 08, 2006 5:04 pm    Post Subject:
finally remember that using aluminium wiring with fittings not designed for it is very dangerous, so is putting it in the same terminal as copper even if the fitting is designed for both.
if you have figures for copper cable you should be able to derive the ones for aluminium pretty easilly, just multiply the figure for copper by the resistivity of copper at your cables temperature rating and divide by the resistivity for aluminium at that temperature.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Sep 08, 2006 6:23 pm    Post Subject:
you`re not wrong, -plugwash icon_eek.gif I had a length of ali going to my cooker from CU..........nearly set fire to the unit.....then it went to 6 mm copper via a 30A junction box.........changed it all before part P
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Sep 08, 2006 10:02 pm    Post Subject:
If Cu & Al don't go together, how come they used to make aluminium conductors coated with copper?
Or indeed imperial cables with tinned copper conductors?
__________________
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Sep 08, 2006 10:05 pm    Post Subject:
i'm not sure on the details i just know special precautions are needed (american wiring sites are very hot on this as such wiring was far more common over there), maybe if the aluminium is completely covered the issues (which i belive are primerally accelerating corrosion arround the joints)
i presume they are tinned with tin not aluminium
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Sep 09, 2006 10:04 am    Post Subject:
But the point you're making presumably is about dissimilar metals reacting against each other?
__________________
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Sep 09, 2006 7:00 pm    Post Subject:
look, i'm not a materials scientist so i don't know exactly why its dangerous and why other metal combinations (e.g. copper and tin or copper and lead) don't pose a problem.
I DO know aluminium is strange stuff though. in air you basically won't get it to burn easilly at all (i think it may be easier if powdered though) but mix it with iron oxide (which should by rights be a reaction that releases less energy than simply burning it) and give it a bit of activation energy and you'll get a hugely intense reaction that is virtually impossible to stop.
Back to top
 Alert Moderators
jeepmadmike
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 11, 2006 8:39 pm    Post Subject:
Ali and copper cables can be joined without a problem as long as the joint is covered with a compound with prevents any electrolytic corrosion, ali cables will burn back during a fault, I repaired a 300mm SWA a few months ago it had been damaged during excavition work and re-buried almost 4 feet of the cores where missing.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
street lighting cable size 6 4060 Wed Dec 31, 2003 8:30 pm
current by size of cable(mm2)? 4 2940 Wed Sep 13, 2006 1:38 pm
size of cable for extension 5 1380 Wed May 07, 2008 7:47 am
Cable size 5 8080 Thu Mar 25, 2004 3:44 pm
size of cables mm˛ for supply 2 880 Tue Sep 21, 2004 12:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
