I want to replace the suite in the downstairs cloakroom. I currently have a low level pan/cistern going into a waste pipe that goes into my concrete floor. I want to replaced the toliet with a close coupled toilet but am unsure how to connect it to the waste. My current toilet has an s-trap so plumbs to the waste directly. I can only find close coupled toilets with p-traps. I have seen waste pipes that have a 90 degrees bend for this but am unsure.
Firstly are these fittings any good (ie do they block easily)?
Secondly my waste pipe is 8" from the wall and the base of a closed couple toilet pan will be sat partially over it. Is the distance they sit from the wall adjustable?
Cheers in advance
Tom
Cheers in advance
Tom
