DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Testing 3 phase
Author Message
Maxxy
from United Kingdom
Thanked: 1 time
PostPosted: Wed Sep 13, 2006 12:20 pm Reply with quote
Just a quick question, when installing a 3 phase balanced motor (no neutral) Is there anyway to do an Earth Fault Loop Impedance test? Or is the only way by calculation after measuring the External loop, and R1R2.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 304 times
PostPosted: Wed Sep 13, 2006 4:32 pm Reply with quote
If you have a two prong EFL tester, one to live, on to earth.
If it is a 3 prong tester, put the neutral on the earth, and the earth on the earth, and the live to the live.
BE AWARE that if the motor is not actually earthed (this is why you are testing), that it will rise to mains voltage when you stick the live on, as the neutral has 'no where' to go.
Back to top
 Alert Moderators
Maxxy
from United Kingdom
Thanked: 1 time
PostPosted: Wed Sep 13, 2006 5:34 pm Reply with quote
Thanks for the quick response. The motor is fully earthed, both by the outer sheath, and a cable inside the armoured cable feeding it.
Its a 3 prong Kewtech tester that ive got. With the method you described, it would be too dangerous, so ill have to stick to calculated readings.
Thanks again
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1095 times
PostPosted: Wed Sep 13, 2006 7:03 pm Reply with quote
[quote="Maxxy"]The motor is fully earthed,
Why? If the motor is fully earthed then there will be no problem. If the motor is not earthed then it will rise to mains potential, but your tester will show this.
If you like, for piece of mind you could carry out an ELV continuity test between the earth at the motor and its source before proceding with the EFLI test.
Back to top
 Alert Moderators
Maxxy
from United Kingdom
Thanked: 1 time
PostPosted: Wed Sep 13, 2006 7:33 pm Reply with quote
Wouldnt attaching the Neutral and Earth probes to the Earth cable send 230v down the Earth for the duration of the test?
The motor is part of an industrial fan, so a lot of metal work around it where we fix it to the roof - which i would be kneeling on when doing the test.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1095 times
PostPosted: Wed Sep 13, 2006 7:42 pm Reply with quote
Yes the tester will 'send 230V down the earth' but it will onlt be a few mA.
Providing there is an earth connected to the motor then the metal work will not come live.
Attaching your tester in this way in no more dangerous that carring out an ELFI test using three test leads.
Back to top
 Alert Moderators
Maxxy
from United Kingdom
Thanked: 1 time
PostPosted: Wed Sep 13, 2006 8:04 pm Reply with quote
Brilliant, thanks alot for clearing that up for me
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Bridging between Phase and CPC etc when testing 13 1660 Fri Dec 21, 2007 3:47 pm
Three phase testing 3 2380 Fri Jun 30, 2006 6:03 pm
3 phase testing 21 5560 Sat May 14, 2005 2:26 pm
PAT testing 3 phase 12 380 Sat Oct 08, 2011 8:30 pm
Testing a three phase supply 8 280 Sat Dec 15, 2012 11:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
