dimmer switch (sliding)
2 Feb 2004
The dimer switch attached to a brass standard lamp is over heating and the slider is not working - light can work at full on and that is all - but the whole mechanism is overheating - don't know what to do to try and repair it or where to go to try and replace it as light is too expensive to throw away.
scottish lassie
i would also ask what watt is the lamp, it may be the lamp is bigger than the dimmer can dim, which is what sounds like has happened
