DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Leaking Tap - Modern type
This topic originated from the How to page called Replacing a washer in a tap
Click here to return to the page called Replacing a washer in a tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ianlighting
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 10:11 am    Post Subject:
Reply with quote Thanks
Sorry for asking a question which must have come around once or twice! I have a bathroom tape that operates with a single pull up lever that can be rotated for hot/cold. Its only 18 months old and drips. Having removed the top with a small allen key through where the handle screws in I can see a complex cartridge affair which fits very snugly. I can see it seems to be contained in a brass nut sort of thing which I could get a spanner around if only it wasnt in the tap body. There\\\'s very litle space to get anything around that nut - maybe only 2-3 mm and its 10mm down inside the body, so whats the trick? Is there a special tool? Many thanks for your help.
Ian
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sat Sep 16, 2006 1:07 pm    Post Subject:
Box spanner?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
non finned radiators modern equivilent 5 860 Sun Apr 13, 2008 3:42 pm
What is the problem with modern boiler PCB's? 14 740 Tue Jan 22, 2008 2:08 pm
Modern room stats? 4 280 Sat Oct 04, 2008 4:56 pm
Kingfisher MKII RS80 boiler - effiency to modern units? 11 320 Tue Jan 27, 2009 6:43 pm
modern replacement for a gate valve? 4 100 Tue Oct 06, 2009 6:46 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
