DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bathroom extractor fan !!
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
dpmc
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 12:21 pm    Post Subject:
Reply with quote Thanks
Help!
I have one fan with 2 black wires (presume it\\\'s AC)and wanna wire it so it comes on with the light.
Can I connect yellow into one,
and blue into another,
I presume I should somehow connect the live red to something but there ain\\\'t nowhere to connect it in the fan!
(Bathroom light switch is outside the room so no pull chord.)
Any advice is appreciated!!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
didthathurt
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 12:42 pm    Post Subject:
We'll need a better mental picture than you've given so far.
Where are the yellow and blue cables you refer to coming from, for starters.? Is this a replacement fan?
Do you have only the light switch and the light at the moment?
Where, relative to the bath/shower do you intend putting this fan?
__________________
Being a professional doesn't mean I'm any good - just that I get paid for doing it!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Sep 16, 2006 3:57 pm    Post Subject:
Re: Bathroom extractor fan !!
You talk as if this is a new fan, as it's not connected up? If so, don't you know what it is?
If not, and you are right in your assumption, and it's rated at 230V AC, you'll be OK. But stand back when you switch it on, just in case you are wrong and it explodes.
I take it as well that you have checked that it is suitable for the location?
It sounds as though you have the wiring for a timed overrun fan, but not that sort of fan, so the permanent live (probably red, but no guarantee, however this is trivial to check with your multimeter) needs to be made safe in a piece of choc-block.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
dpmc
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 5:39 pm    Post Subject:
Thanks for replying,
yes, I'm replacing a fan that was old and broken, so the location is all ok. (There is only one light switch situated outside the room - I hope the yellow switched live is connected somehow to it)
The three wires (red yellow blue) coming out the wall were attached to the old fan. I removed them, replaced the old fan with the new, but the new only had the 2 black wires. I think I left the yellow free- what happened then, was that the fan was permanently on.
The fan is a EMMA (!?) emf4 standard model, 220-240v 50 hz, 20 watt. It was cheap...
So, if I sort out a piece of choc-block for the red wire coming out the wall.... do you think it'll work?
thanks for your advice!!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Sep 16, 2006 7:44 pm    Post Subject:
Doesn't neccessarily follow, I'm afraid.
If your fan is in a certain position, it should either be IPX4 rated and protected by an RCD, or an SELV model.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
dpmc
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 8:02 pm    Post Subject:
not sure what any of that means!
It only says eMF4 on the box. No idea what that implies either.
Not in a rush,so I wont act til I know what's going on.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Sep 16, 2006 8:04 pm    Post Subject:
Where is the fan in relation to the bath/shower cubicle?
Need measurements, please.
Has the fan got an "IP" rating on it?
Is it protected by an RCD?
__________________
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Sep 16, 2006 9:33 pm    Post Subject:
Sounds like the old fan was a timer type and the new fan is not a timer type (ie, the fan runs on after the light has been switched off).
Assumings its a none timer type (only two terminals, maybe marked L & N??)
Put the blue wire into the N terminal, put the yellow wire into the L terminal. Insulate the red wire using a small choc block. The fan should now come on when you switch the light on.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Sep 17, 2006 1:02 am    Post Subject:
Then you should not be doing this.
__________________
Back to top
 Alert Moderators
sparkacus
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 17, 2006 6:36 am    Post Subject:
Agree with BAS on this one. Sounds as though you should contact a qualified electrician. It could also come under "P Regs" if it is in your bathroom!!!
Back to top
 Alert Moderators
dpmc
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 17, 2006 10:02 am    Post Subject:
thanks,
It's above the sink which is next to the shower.
According to the diagrams, it's in zone 2 which is IPX4!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Help - Bathroom extractor fan position? 8 440 Thu Aug 13, 2009 1:48 pm
bathroom extractor fan 5 5800 Wed Feb 21, 2007 10:14 pm
extractor fan in bathroom 3 300 Thu Feb 15, 2007 11:22 pm
bathroom extractor fan advice. 2 160 Mon Sep 07, 2009 11:01 am
Extractor fan location in bathroom 10 5860 Fri Feb 04, 2005 2:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
