Rob Willey gas fire
Status
Not open for further replies.
B
Bamber gaspipe
Have just installed this fire, it won`t ignite via piezo ignition, lights o.k with taper/match etc but won`t have it using normal knob. Checked spark which is present , distance correct, burner pressure is correct after lighting manually, everything checks out, checked for blockages, can`t find reason why it won`t ignite, have phoned Rob Willey to send out Engineer but have I missed something? It`s a Firecharm Living flame by the way.. I have referred it back to the manufacturer for a faulty piezo..any thoughts?
is the electrode sparking in a place that wont do the job of ingniting??
does it spark at all??
Yes, it`s doing all it should. I`ts an oxy pilot fire, I have checked H.T. leads, spark gap & all the rest of it I think... what do you mean Corgi?
Bamber gaspipe said:
That wouldn`t stop the fire from igniting, it may go out afterwards..anyone :cry:
Well I haven't seen it bamber but if the gas is being pulled up the flue before reaching a point where the spark ignites it it won't light.
The gas isn`t being pulled up the flue, the gas is being directed to the appliance. The products of combustion are being sent to the flue..
Excellent, what was it?. I am just curious how you can have gas and an ignition spark in the path of the gas yet no igntion :confused:
Yes just as I thought :rolleyes: , unless you have fitted an automatic damper the flue pulls wheather the fire is lit or not and guess what ?, when there are no poc's it pulls through air and yes, gas, away from the spark.
I am offering you a suggestion based on what you have told us clouseau, but if you prefer to think that the sparking piezo is magically creating an ignition resistant spark then good luck.
But anyway as you say it is sorted so perhaps you can enlighten me?
Yes, I have just fitted one to go with the fire, seeing as it is being installed on a conventional chimney i,e solid brick,conventional,
Behave yourself, you`re winding me up now....
Has anyone fitted a fire particularly this type where the ignition does not fire ..simple question..
Status
